  • Hey everyone! Enter your ride HERE to be a part of December's Ride of the Month Challenge!
Status
Not open for further replies.
1 - 1 of 1 Posts
Also as a reminder repost, we continue to offer the SmartTire pressure monitoring system for your peace of mind as well.
the 2nd Generation SmarTire System can be at your fingertips to warn you of air pressure loss. Additionally, by keeping tires inflated properly, you can maximize performance, fuel economy and tire life all at the same time. And this system can even help protect low profile tires mounted on large diameter wheels by identifying a drop in air pressure long before it becomes visually apparent.
The wireless tire air pressure sensors/transmitters weigh less than 1.5 oz. and are accurate to ±1.5 psi. Straps that accommodate 13" to 20" diameter wheels are used to securely band a sensor to each wheel before the tires are installed. The sensors/transmitters are equipped with motion detectors that turn them off when the vehicle is parked to prolong their lithium batteries' life (estimated at more than 5 years of normal vehicle use).
The system's receiver/display unit is placed within reach and sight of the driver. Within the first minute of driving, the system's sensors will broadcast a signal to the in-car receiver to confirm they are operating correctly. The receiver/display features a 12-volt power cord that can be plugged into the cigarette lighter or hardwired directly to a "keyed" power circuit.
The 2nd Generation SmarTire Tire Pressure Monitoring System is backed by a one-year/unlimited mileage manufacturer's warranty.
NOTE: If purchased with a wheel & tire combination, I ship the package set with your sensors preinstalled into your wheels when we mount, saving you an extra step in the ST install! :thumbup:
http://www.tirerack.com/accessories/smartire/smartire_all.jsp
1 - 1 of 1 Posts
Status
