2002 bmw 330i
rare manual slicktop facelift sedan
silver over grey
folding rear seats
xenon headlights w/ aux driving lights
harmon karden stereo
118k miles
the following components are new or recently replaced:
engine:
valve cover gasket
oil filter housing gasket
camshaft position sensor
air filter
fuel filter
cooling system:
radiator
expansion tank
thermostat
stewart water pump
upper and lower hoses
tensioner
idler pulleys
serpentine belt
suspension:
spec mcs front and rear shocks
spec hypercoil front and rear springs
hotchkis front and rear swaybars
adjustable front and rear swaybar end links
ground control race camber/caster plates
ground control rear shock mounts
ground control adjustable rear spring perches
ground control rear spring alignment hats
rtabs and powerflex limiters
front shock tower reinforcement plates
bimmerworld front control arm bushings
front control arms
wheel studs
brake rotors
brake pads
driveline:
shifter bushings
powerflex rear subframe bushings
rear subframe weld-in reinforcements
diffsonline 3.46 race diff
misc:
air bag recall performed
new headliner
car has been very well maintained and is in excellent condition inside and out. probably the best e46 330 i've owned, and i've owned a lot of them. everything works as it should - power windows, great a/c, no issues with the stereo, no warning lights on the dash. engine starts instantly, idles perfectly, and pulls hard to redline. transmission shifts very well and the clutch is smooth and progressive. no funny smells, no weird vibrations, no unusual noises. new pads and rotors all around with a firm brake pedal and properly working abs. clean title, recent battery and synthetic oil change, needs absolutely nothing.
offered at $15,900. would make an excellent dual purpose street track car, or serve as the starting point for a top of the line se46 build. please email [email protected] for more information.
silver over grey
folding rear seats
118k miles
engine:
valve cover gasket
air filter
fuel filter
cooling system:
radiator
expansion tank
thermostat
stewart water pump
tensioner
idler pulleys
serpentine belt
suspension:
front control arms
wheel studs
brake rotors
brake pads
driveline:
shifter bushings
misc:
new headliner
