1 - 5 of 5 Posts
Update 2:
Turns out I messed something up in the coding somehow. Matching the differences between my old LCM and the 4.0 module solved the issue, although most of the things I rolled back don't seem related to this particular bulb at all.
AUSWERT_PROP_ABWEICHUNG
aktiv
SP_MOTOR_STOP
nicht_aktiv
KALTUEBERWACHUNG_SL_RE
aktiv
KALTUEBERWACHUNG_SL_LI
aktiv
WARMUEBERWACHUNG_SL_RE
aktiv
WARMUEBERWACHUNG_SL_LI
aktiv
BLS_PRUEFEN
nicht_aktiv
NSL_ALS_STANDLICHT
aktiv
CC_RUECKLICHT_2_RECHTS
aktiv
DEF_PIN_29_30_DEFEKT_SL
nicht_aktiv
PWM_ANSTEUERUNG_BL
wert_02
PWM_ANSTEUERUNG_BLK_HI
wert_02
@Matt 330LS thanks for your comment, I got the idea to try the old LCM after reading your post :)
Update:
I swapped the old LCM back in and that seems to fix the problem, so it's either coding or the LCM is faulty. Hmm....
So, this one's been driving me crazy for the past few days:
The inner tail light on my outer left unit (so NOT the fog/reverse light, the regular tail light) stopped working.
What I've ruled out:
-Connector / ground issue (taillight fix is already in place and has been for a while)
-Wire break
-Bulb (duh)
It appears the bulb just is not getting power from the LCM. Tapped the cable near the LCM and checked, and there's no power being sent out. The same bulb on the right side is working properly. Also checked for continuity in the circuit in every conceivable way and it's all intact.
Any ideas?
Additional info:
Vehicle: '02 325i (Facelift, euro, LHD)
-All rear bulbs are standard, except for the reverse lights (LED) and the blinkers (silvervision).
LCM Settings (note: 4.0 LCM retrofitted and properly configured, running fine for about 1.5 years):
FEHLER_BL_BLINKEN
nicht_melden
BETR_STD_NICHT_LOESCHEN
nicht_aktiv
FEHLER_ANHAENGER
melden
SCHALTER_BREMSL_SCHWELLW
wert_01
SCHALTER_BREMSL_WARTEZEIT
wert_01
ABSCHALTUNG_UNTERSPG
wert_01
KALTUEBERWACHUNG_BLK_VO
aktiv
ENTPRELLZAHL_FEHLERERK
wert_01
TASTVERH_KL_58G_MIN
wert_01
ZUWACHS_TASTVERH_KL_58G
wert_01
HEIMLEUCHTEN_AL
nicht_aktiv
HEIMLEUCHTEN_KZL
aktiv
HEIMLEUCHTEN_NSW
nicht_aktiv
HEIMLEUCHTEN_FL
aktiv
HEIMLEUCHTEN_BL
aktiv
ABFRAGEZEIT_AHM
wert_01
MELDUNG_AENDERUNG_DIMMER
wert_01
HEIMLEUCHTEN
wert_02
ADU_UNTERGRENZE
wert_01
ADU_OBERGRENZE
wert_01
LWR_NEIGUNG_KONSTANTE
wert_01
KL58_HELLIGKEITSSTUFE_FLC
wert_01
nicht_aktiv
AUSWERT_GRADIENT
aktiv
EPSILON_DELTA_AV
wert_01
EPSILON_DELTA_A
wert_01
ANHEBUNG_175_KM/H
wert_01
ABSENKUNG_10_KM/H
wert_01
VMAX_BREMSEN
wert_01
VMIN_BREMSEN
wert_01
SCHW_GRAD_BESCHLEUNIGUNG
wert_01
SCHW_GRAD_BREMSEN
wert_01
SCHW_PROP_ABWEICHUNG
wert_01
DIFFERENZ_MSP_DYN_STAT
wert_01
DAUER_DYN_NACHFUEHRUNG
wert_01
ABTASTRATE_DYN
wert_01
MITTELUNGSINTERV_DYN
wert_01
MIN_STEIGUNG_VZ_WECHSEL
wert_01
MITTELUNGSINTERV_VZ_WECHS
wert_01
MINDESTANZAHL_VZ_WECHSEL
wert_01
HOEHENWEG
wert_01
ABTASTRATE_TREND
wert_01
MITTELUNGSINTERV_TREND
wert_01
SCHW_TREND
wert_01
ABWEICHUNG_TREND
wert_01
GRADIENT_SCHLECHTWEG
nicht_aktiv
NACHLAUF_SCHLECHTWEG
wert_01
SAETT_TIMER_SCHLECHTWEG
aktiv
SCHW_GRADIENT_SCHLECHTWEG
wert_01
PWM_ANSTEUERUNG_BL_MITTE
wert_01
PWM_ANSTEUERUNG_FERNLICHT
wert_02
PWM_ANSTEUERUNG_ZUSTZBLK
wert_01
PWM_ANSTEUERUNG_BIXENON
wert_01
SPG_NACHREGELUNG_0
wert_01
SPG_NACHREGELUNG_2
wert_01
SPG_NACHREGELUNG_3
wert_01
KALTUEBERWACHUNG_BL_MI
nicht_aktiv
KALTUEBERWACHUNG_FL
nicht_aktiv
KALTUEBERWACHUNG_KZL_LI
nicht_aktiv
WARMUEBERWACHUNG_BL_MI
nicht_aktiv
WARMUEBERWACHUNG_BLK_VO
aktiv
WARMUEBERWACHUNG_FL
aktiv
WARMUEBERWACHUNG_AL
nicht_aktiv
WARMUEBERWACHUNG_KZL_LI
nicht_aktiv
WARMUEBERWACH_ZUSATZ_BLK
nicht_aktiv
CC_BREMSLICHT_MITTE
nicht_aktiv
CC_BLINKER_VORN
aktiv
CC_NSL_LINKS
aktiv
CC_FERNLICHT
aktiv
CC_KENNZEICHENLEUCHTE_LI
nicht_aktiv
CC_ABBLENDLICHT
aktiv
CC_ZUSATZBLINKER
nicht_aktiv
ANZAHL_QUICK_RUNDEN
wert_01
ZEIT_KALT_RUNDEN
wert_01
ZEIT_KALT_PULSE
wert_01
ZEIT_KALT_PULSE_QUICK
wert_01
ZYKLUS_KALT_RUNDEN_QUICK
wert_01
DEF_PIN_20_DEFEKTBLINKEN
nicht_aktiv
DEF_PIN_37_DEFEKTBLINKEN
nicht_aktiv
PIN_38_RE_LI_MELDEN
rechts_defekt
PIN_38_VO_HI_MELDEN
hinten_defekt
ANHAENGERMODUL_PWM_WERT
wert_01
PIN_29_30_AHM_ERS_FU_GESP
aktiv
PIN_5_10_AHM_ERS_FU_GESP
aktiv
SPG_NACHREGELUNG_LANGSAM
nicht_aktiv
wert_01
U_POTI_DIMMER_MIN
wert_01
U_POTI_DIMMER_DELTA
wert_01
POTI_DIMMER_INVERS
aktiv
POTI_LWR_INVERS
nicht_aktiv
LEUCHTDICHTE_EXPO
aktiv
TELEGRAMM_ZEIT_ZYKLUS
nicht_aktiv
PIN_20_ALS_FRA_LI_VO_2
nicht_aktiv
PIN_37_ALS_FRA_RE_VO_2
nicht_aktiv
DRL_BLK_VORN_GEDIMMT
nicht_aktiv
BLINKIMPULS_WARNBLK
wert_04
BLINKIMPULS_CRASHBLK
wert_04
DRL_BLK_VORNE_2_GEDIMMT
nicht_aktiv
CRASH_WARNBLINKEN
aktiv
CRASH_KLEMME_58G_EIN
aktiv
TAST_WBLKTASTER_MIN
wert_01
TAST_WBLKTASTER_ZUWACHS
wert_01
STEIG_KL58_T_PER_D
wert_01
BIXENON_EIN_BEI_LICHTHUPE
aktiv
PHASE_AUS_GEDIM_LICHT_AUS
aktiv
PWM_WERT2_NSL_ZUSATZFKT
wert_01
PWM_ANSTEUERUNG_BLK_VORN
wert_01
SP_MOTOR_STOP
aktiv
PWM_ANSTEUERUNG_NSL_LI
wert_01
FL_AL_AUS
nicht_aktiv
BLK_H_R_PICT
aktiv
SPG_NACHREGELUNG_1
wert_01
BLK_H_L_PICT
aktiv
BLK_V_R_PICT
aktiv
BLK_V_L_PICT
aktiv
XENON_TIMEOUT
wert_01
XENON_TIME
wert_01
DEF_PIN_37_VOR
nicht_aktiv
DEF_PIN_20_VOR
nicht_aktiv
ST3_SCHWEL
nicht_aktiv
PIN29_30_BL_NSL
aktiv
BFD_SW1_STUFE3
nicht_aktiv
BFD_SW2_STUFE2
nicht_aktiv
PIN5_10_BFD
nicht_aktiv
PWM_ANSTEUERUNG_NSW
wert_01
LOAD_DUMP_U_GR
wert_01
LOAD_DUMP_TIME_OUT
wert_01
LOAD_DUMP_PWM_BLK
wert_01
LOAD_DUMP_EINVER
wert_01
KL_50_FUNK_AKT
nicht_aktiv
LOAD_DUMP
nicht_aktiv
FL_KL_50
nicht_aktiv
NSW_KL_50
nicht_aktiv
LOAD_DUMP_AUSVER
wert_01
WARMUEBERWACHUNG_BLK_HI
aktiv
LOAD_DUMP_KL58G
nicht_aktiv
LOAD_DUMP_P44_45
nicht_aktiv
LOAD_DUMP_P20
nicht_aktiv
LOAD_DUMP_P37
nicht_aktiv
LOAD_DUMP_P38
nicht_aktiv
LOAD_DUMP_P49
nicht_aktiv
NACHREG_DYN_SLOW
nicht_aktiv
SP_BEWERT_OD_ALC_NSW_AUS
aktiv
TREIBER_STOP_OD_ALC_RE_OK
aktiv
LWR_INVERS_OD_ALC_6
wert_01
REF_LAUF_T1_OD_ALC_4
wert_01
BLST1_BLST3
aktiv
BFD_ABS_STUFE3
nicht_aktiv
BFD_STUFE3_TIMER
wert_02
BFD_BLINK_EINZEIT
wert_02
BFD_BLINK_AUSZEIT
wert_02
BFD_SW2_STUFE3
nicht_aktiv
TEST_OD_ST2_OHNE_NSW
nicht_aktiv
SL_VO_ANSTEUERUNG
aktiv
PWM_ANSTEUERUNG_SL_VO_RE
wert_01
PWM_ANSTEUERUNG_SL_VO_LI
wert_01
BEGRENZUNGSLICHT_IN_PARK
aktiv
LAENDERVARIANTE_LSZ
wert_01
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
CC_STANDLICHT_RECHTS
aktiv
CC_STANDLICHT_LINKS
aktiv
SIDEMARKER_US
nicht_aktiv
GEDIMMT_BLK_BEGRENZ_LICHT
nicht_aktiv
DRL_DIMMUNG
wert_01
AH_US_OPTION
nicht_aktiv
LEUCHTWEITENREGELUNG
aktiv
PIN_20_ALS_SIDEMARKER
nicht_aktiv
HEIMLEUCHTEN_KL58G
aktiv
TAXI_ENABLE
nicht_aktiv
FEHLER_NSL_RECHTS
nicht_melden
RECHTS_LINKS
nicht_aktiv
TAGFAHRLICHT_ECE
nicht_aktiv
GED_FL_ALS_DRL
nicht_aktiv
VARIANTE_LSZ
wert_01
LENKSEITE_LSZ
wert_01
KALTUEBERWACHUNG_AL
nicht_aktiv
PWM_ANSTEUERUNG_AL
wert_02
LEUCHTWEITENREG_AUTOM
nicht_aktiv
XENON_TEST
aktiv
LEUCHTWEITENREG_DYNAM
nicht_aktiv
BI_XENON
aktiv
HALB/VOLLSCHRITT
vollschritt
PWM_WERT2_FL_BIXENON
wert_01
FL_UND_NSW_NICHT_GLEICHZ
nicht_aktiv
FEHLER_SCHALTER_BREMSL
nicht_melden
BLS_PRUEFEN
aktiv
LWR_VORZEICHEN
nicht_aktiv
PIN29_30_BFD
nicht_aktiv
FLC_LED_AKTIV
nicht_aktiv
ALC_DEF_AKTIV
nicht_aktiv
ALC_BLK_PER
wert_02
KENNLINIE_LWR_SENSOR_VO
wert_01
KENNLINIE_LWR_SENSOR_HI
wert_01
VMAX_BESCHLEUNIGUNG
wert_01
wert_04
VMIN_BESCHLEUNIGUNG
wert_01
wert_04
DEF_LWR_SENSOR_HI
wert_01
OFFSET_LWR
wert_01
PWM_ANSTEUERUNG_SL3_LI_HI
wert_02
PWM_ANSTEUERUNG_SL3_RE_HI
wert_02
PWM_ANSTEUERUNG_SL2_RE_HI
wert_02
KALTUEBERWACHUNG_RL_3_LI
aktiv
KALTUEBERWACHUNG_RL_3_RE
aktiv
WARMUEBERWACHUNG_RL_3_LI
aktiv
WARMUEBERWACHUNG_RL_3_RE
aktiv
WARMUEBERWACHUNG_RL_2_RE
aktiv
CC_RUECKLICHT_3_LINKS
aktiv
CC_RUECKLICHT_3_RECHTS
aktiv
NSL_ALS_STANDLICHT
nicht_aktiv
PIN_37_ALS_SL_RE_2
aktiv
SL_X_3_ERSETZT_DEFEKT_BL
aktiv
SL_3_ERSETZT_DEFEKT_BLK
aktiv
KALTUEBERWACHUNG_RL_2_RE
nicht_aktiv
nicht_aktiv
PIN_20_ALS_SL_LI_3_ANSTEU
aktiv
PIN_38_ALS_SL_RE_3
aktiv
KALTUEBERWACHUNG_NSL_LI
nicht_aktiv
WARMUEBERWACHUNG_NSL_LI
nicht_aktiv
DEF_PIN_5_10_DEFEKTBLK
aktiv
DEF_PIN_5_10_DEFEKT_SL
nicht_aktiv
P_10_5_ALS_BL_FUNKTION
aktiv
BL_ERSETZ_DEFEKT_SL
aktiv
PWM_WERT2_BLK_ZUSATZFKT
wert_01
DEF_PIN_29_30_DEFEKT_BL
nicht_aktiv
aktiv
STANDLICHT_ALS_BREMSLICHT
aktiv
PWM_WERT2_SL3_ZUSATZFKT
wert_01
BREMSLICHT_ALS_STANDLICHT
aktiv
PIN_20_ALS_NSL
nicht_aktiv
BLK_DIMMEN
nicht_aktiv
INTERM_FL
nicht_aktiv
SCHALTER2_BL
nicht_aktiv
GEDIMMT_BL__BEGRENZ_LICHT
aktiv
PWM_ANSTEUERUNG_SL_LI_HI
wert_02
PWM_ANSTEUERUNG_SL_RE_HI
wert_02
PWM_ANSTEUERUNG_KZL
wert_01
KALTUEBERWACHUNG_RL_LI
aktiv
KALTUEBERWACHUNG_RL_RE
aktiv
KALTUEBERWACH_ZUSATZ_BLK
nicht_aktiv
WARMUEBERWACHUNG_BL
aktiv
WARMUEBERWACHUNG_RL_LI
aktiv
WARMUEBERWACHUNG_RL_RE
aktiv
CC_RUECKLICHT_LINKS
aktiv
CC_RUECKLICHT_RECHTS
aktiv
CC_BREMSLICHT
aktiv
CC_BLINKER_HINTEN
aktiv
PWM_WERT2_ALS_BL_AUSGANG
wert_01
KALTUEBERWACHUNG_BL
aktiv
KALTUEBERWACHUNG_BLK_HI
aktiv
PWM_WERT2_ALS_SL_AUSGANG
wert_02
NSL_ERSETZT_DEFEKT_BL
aktiv
BL_ERSETZT_DEFEKT_BLK
aktiv
SL_ERSETZT_DEFEKT_BLK
aktiv
STANDLICHT_ALS_NSL_LINKS
aktiv
STANDLICHT_ALS_NSL_RECHTS
aktiv
FO_ME_HOME_SL2
nicht_aktiv
PIN37_49_PARKL
nicht_aktiv
PIN38_20_PARK
nicht_aktiv
HEIMLEUCHTEN_SL3_H
aktiv
PIN29_30_PARK
nicht_aktiv
HEIMLEUCHTEN_SL_H
aktiv
HEIMLEUCHTEN_SL_V
aktiv
BFD_MINDEST_GESCHW
wert_02
BFD_STUFE_2_VERZOEG
wert_02
BFD_STUFE_2_MAX_EIN
wert_02
BFD_SW1_STUFE2
nicht_aktiv
BFD_ABS_STUFE2
nicht_aktiv
BFD_STUFE2_TIMER
wert_02
BFD3_ASC_TIMER
wert_02
PIN49_37_BFD
nicht_aktiv
PIN38_20_BFD
nicht_aktiv
M_TELEGRAM_OD_ALC_5
nicht_aktiv
PWM_ANSTEUERUNG_BL
wert_01
wert_01
nicht_aktiv
AL_KL_50
nicht_aktiv
LOAD_DUMP_P5_10
nicht_aktiv
LOAD_DUMP_P30_29
nicht_aktiv
SP_F_EINTR_OD_ALC_NSW_PIC
aktiv
TR_F_EINTR_OD_ALC_AL_FPIC
aktiv
U_POTI_0_OD_FAILSAFE_ON
wert_01
U_POTI_1_OD_DAEMMERSTUFE
wert_01
U_POTI_2_OD_ALC_PARA_01
wert_01
SCHRITT_GRENZE_OD_ALC_IO
wert_01
TEMP_GRENZE_OD_ALC_NIO
wert_01
REF_LAUF_STEP_OD_ALC_2
wert_02
REF_LAUF_ZAHL_OD_ALC_1
wert_02
REF_LAUF_T2_OD_ALC_3
wert_02
TEMP_RAMPE_OD_ALC_8
nicht_aktiv
PROGRAMMPARAMETER_LCM_1
wert_01
PROGRAMMPARAMETER_LCM_2
wert_01
PROGRAMMPARAMETER_LCM_3
wert_01
PROGRAMMPARAMETER_LCM_4
wert_01
PROGRAMMPARAMETER_LCM_5
wert_01
PROGRAMMPARAMETER_LCM_6
wert_01
PROGRAMMPARAMETER_LCM_7
wert_01
PROGRAMMPARAMETER_LCM_8
wert_01
SCHRITTABSTAND_STARTPHASE
kennlinie_01
SCHRITTE_0_OD_ALC_AKTIV_0
wert_01
HYSTERESE_OD_AL_XENON_IO
wert_01
T_STROM_OD_ALC_PARA_02
wert_02
SCHRITTE_1_OD_ALC_AKTIV_1
wert_01
SCHRITTE_2_OD_ALC_AKTIV_2
wert_01
ABS_MIN_2_OD_ALC_AKTIV_3
wert_01
S_MOTORWEG_OD_ALC_7
wert_01
BEI_NSL_KEIN_BFD
nicht_aktiv
CYCL_TI_BLK
dreimal
DAUERFAHRLICHT_US
nicht_aktiv
FL_ALS_SL_LR
nicht_aktiv
FL_DRL_MIT_RL
nicht_aktiv
HEIMLEUCHTEN_BLK
aktiv
LAENGE_LWR_REF
wert_01
wert_02
LAENGE_LWR_STELL
wert_01
wert_02
LH_MIT_BIX
nicht_aktiv
PIN_20_37_ALS_PO
nicht_aktiv
PIN20_PWM_BLK
wert_01
PIN37_PWM_BLK
wert_01
PIN38_BFD
nicht_aktiv
PIN49_BFD
nicht_aktiv
PIN49_PWM_BFD
wert_01
LWR_DIAG_PARAM
wert_01
PO_ALS_DRL
nicht_aktiv
So that's your brake light bulb, correct? I would check the brake light switch for operation. Also, if I recall correctly, the wiring going to the lights at the rear of the car are single wires out of the LCM (control both sides) and then they split to each side farther downstream in the harness. If the brake lights work, and all other lights work, and you're certain you've checked all the grounds (including inside the tail light housing), then you may have to find those splice connectors inside the harness and make sure that bulb's power wire didn't break connection there.
Discussion Starter #3
It's one of the parking/standling lights, the brake light is the top one IIRC (I've had them all coded to work as both for ages so tbh I'm a bit fuzzy on which is which but I'm 99% sure it's not the brake light).
Couldn't find a splice anywhere, I think they are actually separate pins for L/R (I can actually trace the left one all the way from the trunk to the LCM, no breaks, checked with multimeter).
Thanks for your input tho :)
Bulb in question circled in red here for clarification (not my picture but same housing more or less, other side):
908508
I gotcha. Trying to troubleshoot from memory as I'm not at my car. Guess my memory isn't what it once was...
It sounds like you've checked everything. If it were me I'd check everything again and clean the contacts on the bulb and the housing, just to say I'd done it twice. I had an issue on my 330Ci where the passenger tail light (standing light I guess you'd call it, not the brake light) was dimmer than all the others even after a bulb change. Further investigation revealed I had a little burn mark inside the connector harness at the light assembly due to a loose ground wire in the connector. Fixed that and it worked like a champ. Let us know what you figure out. If all else checks out you may have to consider the LCM itself might have an issue, electronics being what they are. My experience, however, has shown me over the years that the vast majority of the time there's an electrical power issue it's due to a bad ground.
Discussion Starter #5
Figured it out, ended up being faulty coding though I have no idea what setting it was that I messed up, just ended up copying all settings from an old setup. Gonna differential that next week. The details are the first post.
Anyone know what "SP_MOTOR_STOP" or "AUSWERT_PROP_ABWEICHUNG" do? 🤔
1 - 5 of 5 Posts
