21 - 40 of 76 Posts
Dan, could you give me at least hint on my question? have made some amendments in full read, checked in Ultimo CS corrector but error ecu selftest doesn't leave!!
I have a problem because I am ripping my 32kbit file and editing it in TunerPro using
"MS42_Rev1-10_64kb.xdf" or "XDF_MS42_328_V6b_Row.XDF"
Unfortunately neither one nor two can find:
"Kf_zwb_sa_n_tkw"
Could someone send me the correct XDF under Ms42 driver?
It is part labelled and sorted for 32kb files. If some of the maps look strange, I was building it before the V6b file was made. The map axis are not complete i some instances.
Your other option is to apply a base offset to the 512kb xdf. It is Ctrl + F2.
http://s000.tinyupload.com/?file_id=00003556627368753221
It needs to remove the vehicle speed sensor so that there is no problem with rev at 5500rpm, how can i do it? What to modify?
thank you
Hello,
My original version of the firmware is 0110025, I write version 01100AD Virgin.
I changed pump parameters:
konf_ssp = 1 (Secondary Air Pump Delete)
epz_inc_rul = 00 (off DTC 96 Auxiliary Air Pump - Function)
epz_inc_slp = 00 (off DCT 35 Aux. Air Injection System Relay)
epz_inc_slv = 00 (off DTC 62 Aux. Air Injection System -Switching Valve)
It displayed me error and a check engine light:
126 activate solenoid valve tank-leck-diagnostic-pump
How to get rid of 126 error?
My car from the original 0110025 firmware doesn't display DTC errors.
I will be very grateful for the solution.
Discussion Starter #40
Hello,
0x481A6 epz_inc_ldp
21 - 40 of 76 Posts
