1 - 5 of 5 Posts
I was able to pull out my shift knob, i was kinda twisting it a little bit while pulling up. But a lock that prevents the knob from rotating is somehow loose or something...any ideas guys? :hmm:
Is NOT A Mechanic
If you noticed, there is a slot at the top of the shifter shaft. The OE locking mechanism uses that to prevent rotation. If you twisted the knob while removing it, you may have broken the clip inside the knob that keeps it still.
You can try adding a couple layers of duct or electrical tape around the top of the shaft, then re-installing the knob. This extra thickness may provide a tighter fit and prevent you from having to buy a new knob.
Hope that helps!
Ken
i have the same problem, i knew i had broken something when i was taking it off i jsut didnt know what! thanks ill try it
1 - 5 of 5 Posts
