1 - 15 of 15 Posts
Just twist the right-side cluster knob until you've added your hour. Also changes your radio if it's still stock.
2004 330i
weird, my alarm clock looks nothing like that
wtf am i gonna do now?
My businesscd does not have the clock icon on the left button. I haven't found a way to set the obc clock as a default setting, it always reverts to outside femp.
Discussion Starter · #9 ·
^ Just to make sure... you are pushing in the turn signal, are you not? You need to do that until the ti:me shows up below the speedo/tach before you can set it. The radio just follows along.
Yes, I don't have a problem with the obc clock, I just wish I could find a way to get the radio clock displayed, or have the obc default to clock instead of the temp
Correct.
More specifically, mine has the minus button, without the radio icon
Radio Clock
On my 323i I have the radio show the time and the dash show the temp; this is the way I want it.
Am I correct that to change the radio displayed time, I must get the dash to first display the time (How do I switch from Temp to Time?), then change the time to daylight saving time. This supposedly changes the radio time display as well. Assuming both change, can I then change the dash display back to TEMP and keep the radio display time?
1 - 15 of 15 Posts
