1 - 9 of 9 Posts
Hello folks!
I am looking for a little help: the car is 325I 2002 vintage with 125k mi. Today SES light came up Autozone read error codes came up as follows:
P0344-cam position sensor intermitten.
Possible causes:
CAM sensor faulty
Wiring faulty
Timing off
Cylinder misfire
P0128-thermostat
Pausible causes:
Thermostat stack open
Faulty CTS
Low coolant level NO IT IS NOT
The question is two error codes comae up simonteneously. Which one is real?
Of course I can spend $200 in parts and replace thermostat and CAM sensor. But prefer to replace only parts that needed to be replace.
By the way, I haven't replaced O2 sensors yet. Could it be a contributing factor?
Thanks in advance for any help.
Best regards,
Relevart
Do both now! Cam sensors go anytime and are known to fail, usually the exhaust sensor first. ONLY !!! buy an OEM from Tischer or your dealer!! There are no good aftermarket sensors around.
Thermostat is known to fail since it is an electrically heated unit. Cooling system in general is a service item anytime after 50K miles. I would go through the system and replace thermostat, coolant pump, hoses and coolant reservoir. When (and not if!!) any of these fail your engine will overheat within seconds.
lol they both are real. Both the T-stat and the cam sensors are known to fail
Discussion Starter #4
Progress report:
24 hours after problem manifested itself;
Current status of the problem: problem dissapeared: in the morning light was still on; in the afternoon it was off with no human intervention under the hood. Cost of the fix is $0:rofl:
I hope this will last long enough to pass inspection.
I guess I am lucky for now At least want to believe it.:bow:
Discussion Starter #5 (Edited)
Today in the morning on the way to work. I filled car with gas at the station, I use almost exclusevly for the past 5 years.
It looked, like somebody replaces the car: The engine would stall almost every time, I dissengage the clutch or shift in to the neutral. Good thing, I commute to work with friend of mine and it was his turn to drive from our meet place.
My first thought was a water in the gas. I also noticed, that needle on temperature gage is not vertical any more: it shows temperature lower than usual.
On the way home, from the place, where I left car, it behaved quite well: no stalling at all. Just a temp gage a little low.
While driving SES light comes on again. Stop at Autozone: P0344: CAM sensor.
After code read, I start car, the SES light is dissapeared. Autozone guy didn't reset codes!
I would guess it is an intermitten contact in the sensor's circuit or it needs certain amount of faults before Turning on SES light.
Any words of wisdom from experts?
Discussion Starter #8 (Edited)
OK. Error P0128 was bogus: nothing wrong with thermostat for now. Just a fluke. The P0344 was real and Oh boy! Did it mess up engine operations. After replacing CAM sensor everything works fine.
Word of caution to every DIY who attempt to replace CAM sensor (as always you shouldn't blindly follow advise from forum; you're responsible for decisions you are making):
Whatever you do do not break vent pipe from valve cover to oil separator. If you do break it you have two options:
a. if it snaps in the middle go get some heat shrink tubing or high temperature electric tape and use those to keep brocken parts together.
b. if you want to restore to original state, listen to me take a long flat screwdriver and break that damn PITA connector ring off the pipe and CAREFULLY work that pipe from the oil separator. Then install new pipe again CAREFULLY work it in down below. The danger is breaking mounting tabs of oil separator.
I can't stop wondering what stuff responsible engineer was smoking/drinking/swallowing, but 30% glass filled Nylon12 is very wrong material for this application. Unless it designed to fail. Yes, 125k mi 7 years, some can make argument, is respectable age...
Any way, oil separator and pipes are made from rigid 30% glass filled Nylon12, after 7 years sitting next to the engine block at temperatures approaching 120degC in summer it bound to become extremely brittle and will not take any load induced by disconnecting plastic pipe that stuck there.
To realize ramifications just read DIY for replacing oil separator.
http://forum.e46fanatics.com/showthread.php?t=555847&highlight=oil+separator
1 - 9 of 9 Posts
