I've discovered my intake cam timing is off by quite a bit, while the exhaust timing is spot-on. I'm wondering what you think of this approach to correcting the problem:
1) Remove the bolt that secures the VANOS piston to the little "splined shaft"
2) Pull the VANOS piston fully forward
3) Rotate the crank as needed to allow loosening the two lower nuts securing the sprocket to the intake cam
4) Rotate the engine to TDC, and loosen the third nut.
5) Loosen the three bolts that secure the sprocket to the cam
6) Rotate the cam/move the splined shaft in or out as needed to correct the intake cam timing
7) Re-tighten the top sprocket nut, to secure the sprocket to the cam
8) Re-install the bolt to secure the VANOS piston to the splined shaft
9) Rotate the engine as needed to re-tighten the other two sprocket nuts
10) Rotate the crank two full turns, stopping on TDC, and re-verify the timing of both cams.
Regards,
Ray L.
Regards,
Ray L.
