Let's talk about getting a S54 swapped legal in California. Now that there are at least (2) known legal swaps that are active on the forum here (@blksab65 & @Bryson) I thought we could get the full story firsthand on how this works. I'll start by saying I don't know much about the process as it has never really been on my radar but its come up a couple time lately and I honestly don't know enough.
On my swaps I swap all the emissions items so my cars don't require any custom DME work to turn off this or that, etc. BUT I do EWS delete the DMEs so we can keep the keys and EWS module original to the car (this does not leave a shadow fault). The other item is I do not swap in the EKPS fuel pump module. The S54 DME has two fuel pump outputs, one for the US EKPS cars and one for the Euro Relay cars, which is the same wiring as a non-M wagon. So I don't modify anything in the fuel pump wiring system, this DOES leave a shadow code for the Fuel Pump Relay (shows in ISTA/INPA but not on a generic scan tool) but does not set the CEL. I know I could go in and suppress the fault but I like the fact the DME software is essentially stock (save for the EWS delete). Set up this way the DME will communicate and show all the readiness codes just like a stock M3 and will pass an OBD2 plug in emissions test.
Now I've read on the M3 forum that those guys are running into issues with California figuring out they have a tune in the DME and thus failing the cars (even though there is no CEL and the readiness codes are set). I imagine that would mean this same issue would also arise on my cars with the EWS delete?
So my first question is, is that correct?
For the cars that are legalized what did it take and what was the process?
What documentation on the donor car is needed?
Thanks!
Thanks!
