Looks like I can kiss another couple grand goodbye! Dinan and SS resonated it is. Thanks George
That should be a really nice setup and results proven thanks to Georges hard work!
It looks like Turner and ECS have photos of both version under one product number. Mind if I ask the source of info for the twin pipe version being out of production?The single pipe dinan e46 cans are still available new at this time, but the double pipe inlet I think is NLA. I highly suggest buying a new silencer since you have maximum noise reduction in mind. The unknown mile used dinan exhaust I have is much louder than the known 60k mile dinan system I was used to hearing. Adding in the shape of the touring also amplified noise in the cab compared to coupe.
Its just a "stock" photo, single pipe E46 mufflers are for the early M52tu cars which are NLA, all M54 E46 cars use the same dual pipe muffler which ARE still available as per Dinan's website.It looks like Turner and ECS have photos of both version under one product number. Mind if I ask the source of info for the twin pipe version being out of production?
At this rate it might be easiest to just fab a 2.5” muffler from scratch..
Thanks, but I should have documented this better.That should be a really nice setup and results proven thanks to Georges hard work!
Do you happen to know the diameter of the single inlet? Ideally I’m looking for a cross sectional area of ~9in^2 or 3.25” OD single.George, you’re not wrong about documentation but that’s easy to say in hindsite. I agree the performance exhaust is the best but well out of reach.
As far as PN is concerned I would contact dinan directly, they’ve been super responsive with me in past. My current dual pipe is on D662-1463, on dinan they are offering d662-4602. Pardon the upside down photo. View attachment 963861
Sadly I didn’t get the PN of the single in any of my documentation shots. But photo for reference, below is a shot comparing z3 and the 328 single like George stated. I installed the 328 on my z3 since the droopy tip is pretty polarizing.
FWIW Bryson, with the amount of custom work I cannot imagine a y adapter would be much more for an exhaust shop to make dinan single inlet work.
So I’m looking a little closer at this. SS sells two versions of this conversion exhaust. One that has 54mm diameter and bolts up in place of a stock S2-back, and another that has 63.5mm diameter but needs to be purchased in sections 1, 2, 3. Wish I’d seen this before I purchased my setup.Now with that said SS does make a conversion kit that replaces the Sec 2 & 3. We found it was not worth any power with the Euro Headers/Cats and stock tune (vs the other options), BUT maybe its worth considering with your SS headers and cats as I imagine you will back it up with a custom tune.
I believe you're correct on the single being 3 inch, but the dual is actually 2.125" with a 2.25" section to form a lap joint.I’m assuming the Dinan is dual 2.25” which would be ~8in^2. A single 3.0” is 7in^2.
Please do a before and after dyno.Edit: The 044806 was in stock on the supersprint website so I went for it. Fingers crossed that it’s not too loud.
.Its just a "stock" photo, single pipe E46 mufflers are for the early M52tu cars which are NLA, all M54 E46 cars use the same dual pipe muffler which ARE still available as per Dinan's website.
*Personally I think the best is the BMW Performance, but you likely aren't going to get one of them so in that case I'd goto the Dinan.
