Thanks folks! I think with the BMW Perf. being NLA, this seals my decision to go Dinan. Major props again to George!
I did some exhaust test a few years back on my stock M3, that car also picked up HP from no muffler to a stock BMW M3 muffler.Very interesting that no muffler made the most torque. Usually you hear about back pressure helping with torque, but this is contradictory to that notion.
Sent from my SM-G970U using Tapatalk
Yes, these are SAE.Dude this is great info. I am very surprised with certain aspects of the ranking, and also very impressed with the BMW factory muffler performance.
These numbers are SAE?
When are you planning to post the Torques?
Thanks again for doing this homeskillet.
Derp.317.35/238.36 (HP/Tq)
Steve you are correct that the Stromung was the only one with a factory S2.The Stromung was the only one run with a factory section two, correct? Do you feel the modified section two was positive or negative for hp/tq figures based on the results? Or would you say all of the results are so close that it is really hard to say if modifying section two for a muffler actually has an effect on the end results?
That sounds downright awful, thanks again for doing this for the community.Steve you are correct that the Stromung was the only one with a factory S2.
I wanted to run the S2 with no muffler but it just didn't work out with scheduling. When I swapped the exhaust systems I had to unbolt everything at the S1 to S2 flange and with Euro headers this is very tight. So we make a pull and I immediately get under the car (because of time). I have multiple burns because everything was so hot, I literally have to cup the cat with my hand to get the nut started on the bolts. We had to stop for lunch right after the Stromung pulls. So the exhaust had time to cool down by the time we got back, I could have swapped the exhaust cold or made pulls and swap it hot. It certainly would have been nice to know.
I've got another configuration I have been thinking about and the SS has an option to remove the resonator. We will be back to try more setups in the future and we will probably do the stock S2 no muffler at that time.
The ZHP muffler piping is smaller in diameter than the M3. The other issue is the M3 S2 piping is "D" shaped. What we did is cut the S2 and then slid the ZHP piping into the S2. Then cut the S2 length wise and crimped and folded it to achieve the correct diameter to weld it to the ZHP piping.I want to weld on the ZHP muffler onto the OEM S2 of the S54.
Do I need a sleeve of some kind if they are different pipe diameters? Or they are 60MM for both?
Hi George,The ZHP muffler piping is smaller in diameter than the M3. The other issue is the M3 S2 piping is "D" shaped. What we did is cut the S2 and then slid the ZHP piping into the S2. Then cut the S2 length wise and crimped and folded it to achieve the correct diameter to weld it to the ZHP piping.
Steve, I'm not really sure what you are asking. It appears that you have a stock E46 M3 setup all the way back, but with a ZHP muffler? Personally I don't think its going to get much quieter than that without chopping up the M3 portion of the exhaust.Does your shop offer an exhaust system that I can purchase for a s54 Touring?
Personally, I think the E36 is nearly the worst option on the list, I would ditch it in a hurry. I honestly don't recall the sound levels of the two, but after seeing the results I would never run an E36 M3 (sorry if that's redundant, but that's how poorly I think the E36 muffler is, lol).Hey @George Hill - I just installed SSV1 headers and a catted section 1 and now the rasp with my stock section 2 and e36 M3 muffler is killing me.
Can you comment on the sound level of the Dinan vs e36 M3 or any of the other stock e46 mufflers? It looks like there's no slam dunk option that is not loud and also flows enough for the airbox + headers, and I'm hoping the Dinan + SS resonated section 2 will give me what I'm looking for.
Now with that said SS does make a conversion kit that replaces the Sec 2 & 3. We found it was not worth any power with the Euro Headers/Cats and stock tune (vs the other options), BUT maybe its worth considering with your SS headers and cats as I imagine you will back it up with a custom tune.Looks like I can kiss another couple grand goodbye! Dinan and SS resonated it is. Thanks George
