2004 325xi- The car has constant pending lean codes for banks 1 and 2, short term fuel trim on idle is a steady 27%, it vibrates decently at idle while in drive/ reverse, but not in park/ neutral. It has a whine that appears at a certain, fairly low cruising throttle position (both with my foot and cruise control), sounds like it's coming from the front/ center area of the car. It occasionally runs rough on cold mornings, like it's running missing a cylinder or two, and dips rpms and dies if you try to give it gas. When I fill it up with more than a bit of gas, getting the car started can be difficult- giving it gas helps keep it from dying, but it'll just stumble and die. This one will happen in phases though- it'll start happening, and then it'll be really bad, and then it'll be fine again. The car also has a weird issue where at 2200-2300 rpm and 2800-3000 rpm it'll make a kind of knocking vibration- always at these rmp ranges, and more commonly in lower gears when accelerating.
I feel like these issues are all connected- I've tried smoking/ pressure testing the intake, and I've yet to find any leaks. One thing I did notice is that if I put pressure/vacuum into the intake and then loosen the oil fill plug, the pressure will rush in/ out instantly, either to fill the vacuum or to escape the manifold. I'm not sure if this indicates that my ccv is operating normally or abnormally, as I've only seen posts about it being clogged, but as all the crankcase vents/ valves I have experience with involve a one way valve, I'm not sure whether or not this is the correct way for this one to operate.
The issues after fueling the car have also led me down the path of possibly having a faulty emissions control solenoid, but I'm not sure how to test this.
