1 - 6 of 6 Posts
I started to hear a rubbing noise coming from the rear wheels when I take a turn... The noise can only be heard when taking a turn at a slow speed. I have the OEM setup 19"'s on my M3, does anybody have the same problem?
I took it to the dealer the other day and he said it could be the emergency brake sticking or a defective wheel.
He rotated the tires to see if that fixed the problem but it hasn't I plan on taking it back in a couple of days. Just wanted to check if anyone had the same noise with the original setup.
Thanks,
Your subject line could be interpreted in a number of ways.... :lmao: .
A defective wheel? WTF is that?
Sounds to me like it could be a brake line or the like.
I know it sounds bad but you may want to have them check the drivetrain for bent axles etc....
i think i have that too. whenever i make a turn, usually right at slow speeds i hear this godawful noise...
Discussion Starter #5
Update
It turns out its the differential, after the dealer lifted the vehicle the right side has excessive play in it so he ordered a replacement...... Good thing its still covered under warranty.
Senior Eurowerkz Member
happy you found the trouble
and are taking care of it under warrenty to. nice going.
bobm3 :thumbup: :thumbup:
1 - 6 of 6 Posts
