Hey folks! I have recently done quite a bit of work on my engine and got it all put back together! Now, I've come across this idle problem that I can not diagnose and have tried to research it to no avail. My hope is that someone has come across this issue before or will be able to help me identify the issue! When engine is cold will run perfectly for a solid 20 - 30 seconds before idle issue. Here is a list of all that I have touch/fixed/replaced:
NOTE: All were torqued and cleaned before reinstall
I am currently running Velocity Stacks and had no issue with idle prior to work.
Here is a video of sound:
I appreciate the help!
- VANOS(seals/rattle kit/filter/oil line) Did not replace solenoid
- Injectors (cleaned/tested/new o-rings)
- Vacuum tube(aluminum) cleaned and replaced 12 o-rings
- Rod bearings/bolts
- ITB's were removed and cleaned (did not take of rod)
- ICV cleaned
- Coils and plugs (are about 2 years old ~10k miles)
- Compressions test (all cylinders around 150psi)
- Smoke test (no leaks detected)
- TPS front and back replaced (reset)
