1 - 6 of 6 Posts
I have already searched and read all of the threads on rotating, but I cant seem to get a consistent answer on this- I DO know that if my tires are staggered I cant rotate but are stock tires on 00'328 sport pakcage staggered?
probably a dumb question but figured I would check before thinking any more about rotating...
thanks
thanks
check the tire sizes on your car. if they are the same then you can rotate but if not you have a staggered setup and rotating is not possible. :idea:
you should have 225/45/17 all around, so rotation is OK. Remember to re-adjust the tire pressure. I have set up @ 36psi on each, so I just check it when I rotate my tires.
Banned
To find out if you are running a staggered setup:
1. Find car
2. Locate tires on car (they are black and circular).
3. Read tire size (this could get complicated, but they should read 225/45/17).
4. Check to see if all 4 tires have the same number (i.e. tire size).
5. Slap yourself
:lmao: Haha I couldn't help myself
Discussion Starter · #6 ·
i know i know :) i didnt have my car at work when i started that post, and I was trying to plan out a service appointment, wasnt sure if front and rear tires were same size...point taken though. im glad I could provide an opportunity for you guys to be so funny. :clap:
1 - 6 of 6 Posts
