1 - 5 of 5 Posts
not sure it could be a relay, or maybe just a loose connection
Discussion Starter #4
Thanks, they were the first think i check
Remove the backseat (lower part) there you will see a black box, open it and check if the gears in it are fine. There is already a solution for it here on the forum.
http://forum.e46fanatics.com/showthread.php?t=704744
Thanks, I read this after switching up the words i used to seach. I will try it out when i get home from work
1 - 5 of 5 Posts
