1 - 3 of 3 Posts
Ok,
So I followed the directions, and took out all the appropriate screws and stuff like that.
The next step includes taking out the fan assembly, so I can get to the stock pulleys.
The problem is I can't get the fan out. Do I need a special tool? The directions say I should be able to pull the fan right out?!
Thanks for the help
John
Beware of pwner
JohnnyM said:
Ok,
Thanks for the help
John
If you have an automatic transmission with the clutch fan, you need a 32mm wrench to take the fan off.
Here's a link:
http://mywebpages.comcast.net/jns-johnson/pulleyinstall.htm
Rogue
I just did mine on a 99 e46 328i... the nut turns clockwise to loosen, and you have to remove all clips for the fan shroud...then it should slip upwards without rad damage.. :thumbup:
1 - 3 of 3 Posts
