1 - 5 of 5 Posts
Hey everyone,
My 2002 330ci's driver-side doorlock has been having problems unlocking for over a year now. I finally got some time and decided to fix it, since it annoys my wife to no end (didn't really bother me haha).
Symptoms using keyfob or central locking.
Locking:
consistently, driver-side & passenger-side doors lock
Unlocking:
driver-side never able to unlock (can hear an electric click/sound/motor, but no unlock). passenger side unlocks
Reading up posts here, I diagnosed it as a problem with the lock/actuator. I ordered the part from getbmwparts. I followed this howto http://forum.e46fanatics.com/showthread.php?t=600213 << VERY helpful.
However, when I plugged it all back in, with the brand new part installed, following to the tee, the same problem is happening, stated above.
What in the heck? I'd like to get my door working properly... Anyone got any tips or bright ideas?
BTW, just in advance of questions, no I did not check error codes to see if the GM5 is misbehaving. Also haven't done any troubleshooting of the relays leading to the actuator itself. I'm digging through more posts about the actuator/lock problem, there are a ton.
Thanks a bunch,
-manny
you answer your own question. it will be wise to start troubleshooting the GM5 since you already replaced the actuator unless you think the part is not working or you didnt replace the part correctly, but based on your comments that's not the case..
1 - 5 of 5 Posts
