replaced 02 sensors now I have misfire
1 reading
14K views 49 replies 9 participants last post by  mvance30
#1 · (Edited)
So my old beat up e46 needed 02 sensors. Was throwing codes for both pre cat 02 sensors. I bought them off of rock auto and did them myself. I'm fairly certain I didn't screw it up. I didn't let the tip of the sensor touch anything, (not sure if that would screw it up) I didn't over torque them and the connectors aren't shorted or fried.
the main two codes I get are p1343 and p1347.
I tried disconnecting the battery for 4 hours and when I did there were still the following codes
p0300
p1343
p1345
p1347
p0134
Besides the 1343 and 1347 all those codes I've never seen come up before. One of them is no activity from 02 sensor (bank 1 sensor 1) but when I deleted them only the 1343 and 1347 come back.
Has anyone seen this before or have any ideas? The exhaust is hot right now and its about 100 degrees it feels like so I figured I'd take a break and see if anyone knows.
The car is crappy and has high miles but I'd really like it for winter time. (cheap awd)
Now I haven't checked the spark plugs or that stuff but they were replaced about 20k ago. I figured since the misfire goes away for about a mile after I clear codes it wouldn't be a fouled plug since that would constantly cause an issue. (im assuming I could be wrong)
One thing one of my managers suggested is that I might have fouled up or burnt up a plug due to the new 02 sensors (the old ones were white so the car was running lean)
#5 ·
Do not swap the O2 sensor wiring if you think you did connect them correctly.
BUT, what brand O2 sensors did you purchase and did you purchase the O2 sensors that already had the connectors installed or did you need to splice the old connectors on the new sensors??
The old O2 sensors were likely working fine. What were the specific codes for the sensors? Heater circuit? This is the only O2 sensor code that is usually valid and usually you can skip replacement for some time if the heater circuit is out.
Chances you may have a Lean condition or broke or cracked a vacuum line while taking the car apart.
Do you have the ability to pull Freeze Frame and Fuel Trim data with your current tool? This would be helpful.
#6 ·
"ULTRA-POWER 2344672 UPSTREAM; Base Model"
I do believe the heater circuit code was up there once and awhile.
p1343
p1347
those were the two main codes that come up.
The car was running lean as far as I can tell. but I don't think I cracked a vacuum line. The pre cat 02 sensors are right there at the top easy access. I only had to move the bracket for the air pump. any lines going to that are still good.
I cant. I just have a peak tool.
#7 ·
:facepalm:
The Peake Reader is a boat anchor when it comes to driveability issues.
Sorry, but this is the truth. You have not ability to monitor Live/Realtime data, Fuel Trim values, Freeze Frame info. You have to get a decent tool that will do these things.
I can almost guarantee there is one or more vacuum leak. Everything to CCV and hoses, Intake Boots, DISA or brake booster.
Get an OBDII smart phone/tablet App and interface, typically $30 or less. These Apps are usually best for drivability issues and they support Emission Readiness Monitor Status, Freeze Frame and Live/Realtime data. They are also great for Logging data for review after the car has been driven and can really help find unusual problems.
Android - Touch Scan for $5.00 and ELM327 OBDII to Bluetooth interface.
iProduct - OBD Fusion for $9.99 and ELM327 OBDII to Wifi interface.
Some people prefer to have an extension cable to keep the interface away from their feet.
Something like these cables are often of interested:
http://www.amazon.com/gp/product/B0...oduct/B00JKOSAVS?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A13I33IUTGJ9BK
http://www.amazon.com/OBDII-Extensi...t-144201/dp/B000SBCHCA/ref=pd_sim_sbs_263_5?ie=UTF8&refRID=1D2JWFQ9HPSGWZ2SB34Q
I usually suggest getting the OBDII interfaces from Amazon if you are located in the US/North America. Make sure you choose an interface that indicates that the order will be "Fulfilled by Amazon" otherwise you may be waiting for WEEKS for an interface to arrive from Asia. Ebay is another option, but pay attention where the interface will be shipped from, again weeks for an interface from Asia, so if you can wait and want to try to save some money, go for it, but if you need an interface soon, choose wisely.
#22 ·
Smoke test is the quickest and best way to find vacuum leaks. OBDII App will not tell you where the problems are or what needs to be replaced, but will tell you how bad your problem is and if you are closer to resolving it.
Forget the fuel pump pressure test, it is misleading. You need to do a fuel pressure and volume test, but why bother, the pump is 12+ years old, it needs to be replaced. Why get stranded on the coldest day of the year. Ask me how I know, but i was lucky.
#23 ·
OK so I got to work this morning and let the car idle for 30 minutes (yea I know not the best thing for carbon build up) and I was able to drive it for 5 miles without misfires. I'll attempt to get it home tonight if I can do the same thing and then replace the fuel pump. the Valve cover gasket I did myself when I first bought the car and actually did it correctly so I'm hoping thats not an issue. I'll check for leaks today but my brief search came up with nothing.
#28 · (Edited)
Not sure I can make much out what is provided. What I can say is the Freeze Frame info shows misfiring while cruising which is most likely MAF or fuel pump.
Personnaly I would recommend a fuel pump for any E series BMW due to age.
Really need Log data. Read this info, it is not fully complete but may give you some ideas.
Also note fuel system status for Bank #1 is 8 which means there is a fault of some sort for this Bank.
Not sure I understand the low Voltage comment. 13.5 volts to 14.5 Volts is fine.
http://forum.e46fanatics.com/showthread.php?t=1080334
#29 · (Edited)
I commented in your other thread on Touch Scan.
You need to spend 20-30 minutes playing with it. The problem with ALL smart phone/tablet Apps is they only have 1 physical button, a few soft buttons and a LOT of hidden menus from pressing and holding on the screen.
Touch Scan is FAR more intuitive than other Apps.
First change the MAF reading from Pounds/Min to Grams/Sec, stupid EASY.
Settings, Units, Airflow, choose g/s.
Temp sometimes can be more useful in C vs F, but no so critical.
Settings, Log Setup then set the following:
Logging Enabled - checked
Logging Trigger - choose Trigger at a fixed sample time
Sample Time - choose 1000 msec
Log GPS Items - suggest you unselect it as to not advertise where you live
Select Items to Log - This varies a bit for each car. But here is a list I like to see:
Fuel - do not check any of these 3 items
SAE PID's:
Fuel system 1 status
Fuel system 2 status
Calculated load value
Engine coolant temperature
Short term fuel % trim - Bank 1
Long term fuel % trim - Bank 1
Short term fuel % trim - Bank 2
Long term fuel % trim - Bank 2
Engine RPM
Vehicle speed
Ignition timing advance for #1 cylinder
Intake air temperature
Mass air flow rate
O2 Voltage (Bank 1, Sensor 1) - not all cars have this
O2 Voltage (Bank 1, Sensor 2) - not all cars have this
O2 Voltage (Bank 2, Sensor 1)
O2 Voltage (Bank 2, Sensor 2)
O2 sensor Voltage wide range (Bank 1, Sensor 1) - not all cars have this
O2 sensor Voltage wide range (Bank 2, Sensor 1) - not all cars have this
Input Voltage read by the scan tool
Before you clear codes, get the Freeze Frame data and email or save the screen shot if this is an option. Freeze Frame data saves about 20+ questions as to what is going on.
I copy and pasted that post into here so I can have quick access.
One of the screens the voltage goes from .75 to .25
but when I get home tonight I'll program the app like you mentioned in the thread and post results.
now that the car is home I have most of the tools, skills and money to repair most likely whatever is needed to be replaced I just don't want to spend a few hundred on a fuel pump without knowing thats the issue. If it turns out to be worse and not worth the time or effort (head needs a rebuild or something like that) then It'd just be a waste of money.
stupid question but is there a way to tell if the fuel filter is bad? I'm going to check it out tonight but is there a sure fire way to figure out if its bad?
#36 · (Edited)
You have to be patient, I am working on about 3 1/2 sleep after driving 1100 miles in 15 hours, 45 minutes straight. Do the math on that one! I'm a bit off my Cannonball Run time.
Anyway, would like to see the Fuel Trim info, not sure why this is missing.
Looking at the O2 sensors, the Pre-Cats look pretty good. The Post-Cat Bank #1 looks lazy/bad. But the Post-Cat sensor is not factoring into the current problem.
Looking at the Bank #1 Pre & Post sensors they both react to what appears to the same event an go Lean at the same time.
My first guess would be possible fuel pump unless the sensor faulty.
If you did not want to spend money, you could remove both sensors and swap them for a test and see what happens.
#37 · (Edited)
the post cat 02 sensors haven't been replaced yet by me. If they're the same age as the pre cat ones, they need to be changed. I ordered both previously but haven't installed them yet.
I'm not sure why the Fuel Trim info is missing. I was swapping back and forth on my phone from this thread to the app to program it. I guess I missed that one.
Good luck on your drive pull over and get sleep if you need it. Also if you make your coffee using redbull it does wonders for keeping you awake! ;)
my coworker takes his girlfriend's e46 to work sometimes, its a 325i coupe manual and its a few years newer, if I got a data log from that (since its running fine) do you think it would help to compare?
#38 · (Edited)
Double check what Fuel Trim items you are choosing to Log, you may have selected the wrong item. As I recall most of the Apps will show you Live data and/or have the reporting PID's highlighted or color coded.
I do not need to see a "good car", I have looked at enough data, I can usually figure something out, but sometimes it needs someone that can get hands on and do some more digging.
Don't worry, my 1100 mile leg was a one shot run and I am home now, I went to bed about 2:30 this morning, and was up at 6 am and I am still going, probably will not call it a night until midnight tonight.
My teenage son cannot keep up with the "old man"!
#40 ·
OK fuel filter replaced. Pretty easy job except for stupid things. (hose clamps can only be loosened but cant be tightened, had to go buy new ones) Its still misfiring though.
Here is what the fuel looked like coming out of the inlet side of the fuel filter. but it only came out black from one of the ports I'm not sure if that means anything.
I hope this data log has the info you need. If it doesn't im not sure what to select. Im using that touchscan app.
http://www.filedropper.com/csvlog20150826120224
#41 ·
ok heres another log.
http://www.filedropper.com/4_5
i selected everything that the app said it can log from my vehicle. I dont know if every option is on the log though. I hope between all that I sent you can see something.
I didn't replace the fuel pump yet but I did check for vacuum leaks again using carb cleaner. I didn't see any. I'll try a smoke test but I'm fairly confident.
#42 ·
Not sure what is going on with your latest Log, lots of missing data points.
Double check and see what the Logging Trigger is set to, it should be set to a fixed sample rate.
Not 100% sure what is going on, I can see the Fuel Control system is going into Open Loop due to System Failure later in the log.
You may want to check just for fun the fuses in the DME box under the hood.
