Came across thread recommending to replace oil cap as PM. First I've heard of this. True? If so, why? Thanks.
Actually the the only think the oil catch can does is not drain back into the crankcase. Also the way many set up the OCC they end up with too much/more vacuum in the crankcase and this can actually cause more issues.A lot of people bypass and run into a catch can on here. This takes the oil system off of vacuum but you have to empty the can once in a while.
