1 - 8 of 8 Posts
Just Marinatin'
do you have a coupe or sedan?
I know how to do it but I have a sedan and I am not sure about the coupes.
Just Marinatin'
well I guess
All that you have to do is open the door and gently gently push up on the end where it meets the edge of the door. The window sill pieces are just pressure fitted and not clipped. Just make sure that you do it really slow and evenly or the chrome will bend really really easily. Then for the window surround I would start at the front and all you have to do is just pull out on it. It snaps out of place and then just gently follow the underside with your fingers to release all the other snaps until you get to the rear. You will then be able to do the rear snaps. There should be like three of them and it is okay to just snap them out but you might have to lift the whole assembly up and towards the rear to get the last one. Just do everything really gently and slowly and you should be okay.
1 - 8 of 8 Posts
