Removing trunk liner
23K views 5 replies 5 participants last post by  Dirtboy
#1 ·
I want to add an xm commander via a blitzsafe adapter to my 2001 325i, and also am debating adding a sub. I know the changer wire is on the left of the trunk, but I cannot get the liner out. I removed the black pins but it seems like it is so stiff it will break things if I force it out. Are there any tricks to it or am i missing something. There is a little tray on the bottom of that side of the trunk that i cannot figure out how to remove. ANy help on this would be greeat, thanks.
#3 ·
the tray needs to come out, if I remember correctly...
There are a couple pins that hold it in, the when that comes out, and with the other pins out, I think the liner will come right out
#4 ·
Dont' forget to remove the big black plastic piece right in the back of the seats. This holds the back portion of the backing/liner together. If i remember correctly, the liner is inserted into small grooves along the trunk. Simply start behind the tail lights and work your way around. It took me about 5 - 10 min to remove them so that I can get to the rear shocks.
