1 - 4 of 4 Posts
2004 330ci (6MT Swap)
Yes, camber arms will help with tread wear. Bmws were designed with negative camber in mind. If you do replace them and have the car aligned at a shop, make sure you tell them how much camber you want. Again, factory spec is to have some degree of negative camber. Not sure what that number is but I know all 4 tires will wear on the inside quicker than the rest
1 - 4 of 4 Posts
