1 - 7 of 7 Posts
i can't unscrew the bolt that holds the shock in place. therefore i cannot get the spring either. anyway i can try to loosen the spring. i tried wd40 and applying more force cracked the wratchet bolt thingy. any tricks or tips. i finally got the fronts installed. help please
Discussion Starter · #3 ·
its the lower bolt the one that attaches the shock to the control arm. the nut is incredibly hard to unscrew. need something with more torque or leverage.
Leverage
Or use a 12-15" pipe as a sleeve to the ratchet handle...works too.. :thumbup:
yogo_jonzo said:
You try using a breaker bar? I went and got one when taking an axle nut off of a friends car and it worked out awesome.
is on da floor
if you cant use a pipe to break the bar (which i used) loosen the bolt on the top of the shock mount inside the trunk (remove carpet) and it will drop down also.
1 - 7 of 7 Posts
