Rear M-tech2 bumper alignment & gap fix
815 Views 8 Replies 7 Participants Last post by  paraklas
9
Finally got to fix my rear bumper. The bumper cover ends were protruding outside on both sides and also had a gap of around 10mm. To fix, I used the 3D printed brackets from trinitygraphicsnc with new clips. The new brackets allow adjustment inwards plus some rotation and are much thicker than OEM so they grab the bumper cover more tight. They reuse the same 10mm nuts.
Installation is straightfortward. Took the 2 large bumper bolts out which I found they were rusted to hell and nearly snapped them which allowed to slide the bumper a bit out to replace the guides. I also removed the inner fender liners to do that (a couple of 8mm screws + 10mm plastic nuts). The fender liners gave me some hard time as the larger 3d guides interfered a bit. I used my heat gun to soften the liner a bit and it went back to place 100%.
Hooks:
Rectangle Font Electric blue Magenta Brand
Wood Line Bumper Font Gas
Hand Hat Cap Finger Fedora
Hand Automotive tire Glove Wood Gesture
Wood Gas Automotive tire Electric blue Composite material
Tire Wheel Automotive tire Motor vehicle Tread
Motor vehicle Automotive tire Hood Automotive lighting Tread
Automotive parking light Hood Automotive tire Automotive lighting Automotive mirror
Automotive side-view mirror Automotive lighting Hood Car Automotive tire
See less See more
  • Like
  • Helpful
Reactions: 5
1 - 9 of 9 Posts
Good write up. I'll need to look into the rear bumper, as mine seems to sit lower than stock, and the mounting hardware looks sad
Interesting. I've never been 100% satisfied with how my retrofitted front M-Sport bumper fits. I set the (new) factory brackets as high up and in as they'll go but I still don't think it's quite perfect. Looks like that firm does front brackets too:
Trinity Graphics Inc.
lovely
but i'll wait to find them on Thingiverse..
lovely
Shame there isn't a mechanism where you can pay them for their IP but print locally, to save the cost and emissions of shipping halfway around the world.
  • Like
Reactions: 1
Business idea right there!
Trying to resurrect this thread. I am planning to retrofit an M-Tech style rear bumper on a 323i pre-facelift sedan. Can anyone tell me if the brackets from BMW E46 Upgraded Rear Bumper Brackets will work and needed?
See less See more
Hooks:
Hi Paraklas,
How are those 3D printed brackets working? Did you also get the brackets for the front bumper?
They look very sturdy.
Anyone using the front brackets from this company?
Hi Paraklas,
They are working fine, my bumper is still spot-on. I also got the front bumper brackets installed but I haven't aligned the bumper yet as I was taking it out every other day for some other projects. Will do it soon.
1 - 9 of 9 Posts
