Really bad manual tranny fluid?
666 Views 18 Replies 15 Participants Last post by  mrkprsn
I bought a used ZF 5 speed manual transmission, and drained the fluid, it is a slightly viscous grey. And thoughts on what would cause this?
See less See more
  • Wow
Reactions: 2
1 - 19 of 19 Posts
water leaked in from flood? Total no idea why it turned grey color, unless there is a lot of metal/composite powders from worn out synchro rings mixed in the oil.
  • Like
Reactions: 1
Yes, I would guess water.
If you heat some of it does steam come out and does it boil?
  • Like
Reactions: 3
Looks like you need some more aggregate for that concrete mix its too droopy
  • Haha
  • Like
  • Love
Reactions: 5
Wishful thinking but maybe it had some MOS2 additive?
If there was water in it I'd imagine it would begin to separate after sitting for some time
  • Like
Reactions: 4
Maybe, maybe not. None of these fluids are neat oils. Some easily emulsify water. Some synthetic "oils" are water soluble.
Deliberate additive could be a good shout. I thinking it would look more emulsified if it was water, more beige than grey, and thicker. But I've never actually seen water mixed with gearbox oil.
Is it magnetic at all? A magnet would attract any suspended fine metal shavings.
It does look alot like a Moly additive ... what's the consistency? Oily, watery??
So THAT's what happens with 'lifetime no-fill' !
  • Haha
Reactions: 1
Just refill with transmission gear oil, maybe drain it again in 1000 miles.
Water mixed with oil is a distinctive tan color, definitely not grey.
I'll second the likelihood of an oil-additive.
The synchros add their own almost- black material over time, too,
so while my first guess is some condensation,
hopefully it's additive, and it's been in there quite a while.
I WOULD use a clear, lighter oil and change it twice in 500 mile succession,
making sure to run the car relatively hard for at least an hour at a time,
just to really rinse it out.
t
not an additive fan.
  • Like
Reactions: 1
Send a sample to Blackstone. Was the donor car a hurricane flood recovery?
I miss the days of cheap low mileage ZF320's
3
I saw a similar thing in the rear diff fluid when I took the back cover off to reseal it & changed the leaking output shaft seals at around 160k miles or so.
The magnet did interesting things with it, including being able to pick up the paper towels I was cleaning up with.
See less See more
As we all know, “lifetime fluids” was a marketing ploy, and not a maintenance philosophy.
It is safe to say that my fluid gave its life to the transmission, so it did last a lifetime. ;)
Is there any way to flush it while it is on the bench?
Acetone, brake cleaner, gasoline.
No smoking while doing this.
Do it outside so fumes can't get to an ignition point, like a water heater, furnace, etc.
Alternatively, you can very lightly drive it for 50 miles or so using automatic transmission fluid in place of gear lube, then drain it and add the right stuff. ATF is chock full of detergent.
  • Like
Reactions: 1
That color looks like the lower unit oil that you replace in an outboard engine after its been in the unit for a long time.
1 - 19 of 19 Posts
