1 - 5 of 5 Posts
rattle sound in somewhere front, but if i hold clutch, the rattle sound disappeared.anyone know what problem it is? thanks
check your exhaust hanger. it's located somewhere below shifter area.
mine rusted/burned off. and yes it would only rattle when letting off the clutch or driving.
Discussion Starter · #3 ·
u know how much to replace it? is it under warranty?
According to realoem.com, it's a ~$6-7 part.
But you should find out if it's that what is causing the rattle. Does it rattle when idling? If so, put in in neutral, pull the ebrake, get out of the car and take a look underneath the car. As I said, it's located in area just below the shifter.
I saw mine 'dancing' on top of the exhaust.
Discussion Starter · #5 ·
no. the rattle is from front, near the belt and fan. ONLY rattle when idling after driving,actually. i found that, after i hold the clutch for 3 sec, when i go to check where the rattle is, it disappeared. so, it only happen after driving, then i press some times clutch, then the sound disappear... :werd:
1 - 5 of 5 Posts
