1 - 4 of 4 Posts
Hey guys I have a 2000 BMW 328ci with 150,000 miles that has been
Sitting for the past 6 months due to a fender bender
During that time a rodent chewed thru the blue/white wire in
The fuel pump connector harness.I ran a jumper wire from the fuse box to connector and fuel pump works now but it still doesn't turn over.it
Cranks but doesn't turn over.Any suggestions on what to check out next?
Any help would be greatly appreciated!!!
First check fuel pressure at the rail
FYI- Turning over is when you turn the key to the start positioin and the engine cranks, or turns over. I think you are confusing that with the engine firing, which would happen after you crank the engine if you had gas, air, compression and spark.
That being said, I would check all the fuses, look for other damage from the rodents, make sure you have all four of the above mentioned items and give it another try.
1 - 4 of 4 Posts
