1 - 1 of 1 Posts
Need some help.
Within the past month I've been experiencing something really weird.
Brake, ABS, DSC(Traction) lights would light up accompanied by the radio turning off and on and in some cases odometer, MPG, clock, MPH memory from computer gets wiped. Car will turn on and does not have any problems starting.
I've had rough idle problems before and I think I might have fixed the issue by cleaning my ICV.
I've had Rogue Engineering Underdrive Pulleys since 2004.
Change my belts just last year.
Checked alternator voltage: 13.6 - 13.9 volts when vehicle is running with load. Will show 14 volts every now and then but stays around 13.6 - 13.9 V
This actually started happening one VERY windy/sandy morning in El Paso, TX.
any help would be greatly appreciated, thanks!
1 - 1 of 1 Posts
