1 - 20 of 118 Posts
so i recently emailed raceland to inquire on how their stuff is made and this is the response i got back. pretty interesting
Our
coil springs are chrome silicone wire and those are heat treated and
pre-blocked to prevent sagging. Phosphate coated to prevent rusting and
then powder coated. The springs are wound by ISRI. ISRI is the main
German coil spring supplier for the German automobile industry. Our
galvanized front struts are with self-adjusting shock absorber (gas
pressurized) and adjust themselves to your driving style.
just thought id throw this out there might clear the air a little bit.
Premium Member
i dont doubt the quality of the coils, its the shocks that im suspect about.
good stuff tho, thanks
:facepalm: That means nothing.. that's just the process for spring making. The question is, are the spring rates good for the car? Are they matched to the shocks? Are the shocks good? Are the welds good? etc. etc. etc. Raceland doesn't even have a shock dyno available.
Premium Member
self adjusting shocks huh?
i have the raceland springs! and i live them! the quality is really good i was super suprised lol...its not to stiff! and the handeling is actually rather good expecially the fact i dont have a sway bar in the front. i recomment these to anyone that hasnt already spent 1200$+ on a suspention.
hmm..
i ment raceland coilovers
hmm..
Credible source? Not.
Our
-Spring material sounds good, and for that type of material, they are always going to be heat treated, so repeating that feature is redundant.
-Phosphate coated also sounds good. If I remember correctly, that is what BMW does to the E46 chassis as rust prevention.
-Galvanized struts... That sounds a bit iffy, as I know depending on the process, can get either a pretty good, or very bad finish.
-Self adjusting... I call BS on that part. Involving stuff of that sort is complex, increasing chances of problems, and adds to cost significantly. Doing this properly is so expensive and difficult not many successful suspension companies use this.
-gas pressurized isn't anything special, OEM shocks on just about every car are gas pressurized.
-Also there is no mention of significant testing or design, nor motorsports or manufacturer involvement. Something companies like Ohlins, Bilstein, Sachs, and others can claim.
EDIT: I kinda wanted to say in before BMW_Matt, but too late.
Banned
we need this gif enhanced
1 - 20 of 118 Posts
