There is a ridge on the flange of the pulleys -- one side only. does this higher ridge go toward the front of the car or the engine side? Put another way, does it matter which side of the pulleys is facing out? Right now, I am putting the higher plange toward the engine, assuming you need the lower ridge tioward the front so you can more easily mount the belt.
Thanks.
Thanks.
