1 - 4 of 4 Posts
Driver
1) what are the correct tire pressures for stock 205/60/16 Continental tires on a sedan?
2) my rear S-03's are bald, so I took them off. The fronts still have plenty of tread. Could I get new tires for the rears and run them with the same front tires?
3) from above... if it's okay to run new rear tires with used front tires, would they have to be S-03's? or could I run S-03's in front and Yokohama AVS's in back, for example?
4) also from above, should I move my used S-03's to the rear and get new front tires?
thanks!!!
1 - 4 of 4 Posts
