1 - 3 of 3 Posts
Just got my 19" ACS Rims/tires.....Within the package, it also comes with 4 sets of 5mm spacers...Shoud I just install 2 in the rears or do I run all 4???Will it cause any rub?? Also the tire and rims are already mounted....how much does it cost just to get them install? Since I am getting new rims/tires....Do I have to have the alignment done as well? Thank you so much for all your help!!!
Regards,
Discussion Starter · #2 ·
Anyone...:dunno:
Thanks so much....:thumbup:
they aren't required on the 330Ci, my suggestion is to put them on first, and then see if you want them to come out further. If you are using a 235/35/19 all around, it should work without rubbing either with or without the spacer (+43 vs +36). It's all your personal preference. Personally, i'd put them on...+43 looks kind of weak IMO.
BTW the spacer is 7mm, not 5.
1 - 3 of 3 Posts
