1 - 10 of 10 Posts
those are replicas but i think they should fit
If I remember correctly (from the day when i was doing research before buying my 19's)...
19 inch rims will only fit on a sedan if you roll the fenders (bump up the wheel well)
19 inch rims will only fit a coupe if you don't have a drop
Now, in either case you can roll the fenders and you will be fine but I would most certainly suggest doing this prior to buying 19 inch rims (especially if you want fat tires in the back)
PS: if ^^^ is your gf (in the mini skirt)... :drool:
Discussion Starter · #7 ·
Gf :woot: No she is a cheerleader at my school Texas a&m -
I dont have a drop on my 323CI - so hopefully the 19' will fit fince n my car-
it should fit... just get thin rear tires (no wider than 235)
Discussion Starter · #10 ·
I still have a question please ;
The listsing says; Front 18 x 8" - 35mm / Rear 19 x 9 - 45mm
Would that work? fits my 323CI 00?
Is it fine to have 18 front and 19 rear?
Please advice
1 - 10 of 10 Posts
