1 - 3 of 3 Posts
does anyone have any answers or opinions on tire warm up? i have a shake every morning that eventually goes away after about 20 minutes of driving. everything is balanced, the tires are kumho's ecsta with about 600 miles on them, 245/35/19 275/30/19.
thoughts?
:eek: 20 mins. worth of shake? That sounds really dangerous...maybe try re-torqueing your wheels? Make sure every single lug bolt is tight at ~87 ft.lbs. (if you've got OEM wheels). Otherwise, check torque specs for whatever size lug bolts you're using, etc.
Cuz street tires don't actually take very long to warm up...in a few miles they should already be pretty decent =O
^^^ the shake woulnt just go away after 20 min if that was the case...more likely something else......did the shake start after you installed aftermarket rims and tires??
1 - 3 of 3 Posts
