So right now i'm running a ground control kit. My front springs from what i've measured is a 6" tall spring at 525lbs.
If i wanted to drop down to a 5" spring or 5.5", to keep the same 'ride quality' (for the lack of a better term) would i have to go higher in spring rate? or can i use the same spring rate?
The reason why i ask this is because, i want a tad bit lower(i know, call me a fool), and i'm already totally dropped on the front adjuster. I know technically, i can get thinner camber plates, but the price of two springs is a lot cheaper.
FYI- i do not plan to drop the car, an extra inch, i would just be raising the adjuster up, to compensate for the shorter spring.
-Raj
p/s... correct forum? i can't tell, since this is based off more of a performance question, i posted in here rather than suspension. move if needed.
-Raj
