1 - 9 of 9 Posts
· "DPErt-ASchnizA-*****"
hahahaha, mike's got no looove......
awww
well according to specs, 19x8.5 PG2s ET is 38, you can safely run up to 32 in the rear (BBS LM) with 235 tires. so that gives u 6mms. so you can get 5mm spacers or if they have slightly bigger, 7mm spacers will do too.
· Registered
Discussion Starter · #3 ·
awww
Hey Mike, guess what--> :flipoff: HAHAHAHA, J/K...
Thanks for the info, Mike...:thumbup:
· call me kev :D
spacer is just spacer man.. as long as it's the right spacer for bimmer, then it will work
H&R has spacer too, mike, i know a shop around here that has a lot of spacers in stock, i am sure they will let you try them on before you buy them :)
goto pepboys and get those cheap spacers, they'll fit any bolt pattern.
1 - 9 of 9 Posts
