You do not need to bake your lights, you just pop up the clips holding the lenses and take them out. The gasket should be fine, but what does cause some condensation is if your high beam boot is not seated all the way. By the way, make sure the two black plastic guides on the headlight housing are not pinched in when you put the lenses back on.
