I finally got around to getting it all together. So here it is. Please no flames on the way its set up, i did it just to get up I will make it look pretty later.
For all those who want to know here ya go...
http://john.northsyde.com/DIY/DIY.htm
Enjoy...
The short of it is like this. It took me about 3 hours and you will need basic tools and a dremel. I didnt know at first you needed to cut up the console but you will. You will need to only cut the underside of the console to make room for the switch. You will not need to remove or cut the carpeting to make it fit...
This was a very simple mod, even though the need for a dremel was there anyone could do this themselves , with some pactience and time...
Good luck all
John V
Enjoy...
Good luck all
John V
