1 - 20 of 71 Posts
Here are the pump gas numbers at 12.5psi....notice...no smoothing! :)
:yikes::yikes:!!! can you do custom tunes on S/C setups?
Nice, what octane? Looks like boost tapered down from 15psi @ 72mph to ~12.5 at 120mph -- is that to be expected or just the initial results?
Discussion Starter · #5 ·
91 octane, yes it makes a bit more when it hits the gate...not quite 15, but it makes it's peak power at 12.5. I didn't get crazy with the tune...it's safe. :)
How did you get pretty much the same whp with 5 less psi over the aem. Def awesome!!! I want this. I was thinking of going to 2.75 but Ive changed my mind and now want this before I get a bigger turbo and exhuast.
So for us 2.5 guys, what will we all need to add, injectors, what pump...etc
Very Nice. I wonder what the numbers would be on a Stage 1 HPF kit on 91 Pump Gas with your ProEFI setup.
Discussion Starter · #8 ·
Discussion Starter · #9 ·
If your going to run the same fuel, you won't have to change anything in the fuel system. To be able to run a true flex fuel and a full mix of e85, you will want FIC 1100cc injectors (what we are using), an addtional Bosch 044 pump (not in line), modify the stock hat, modify the stock rail, and add a regulator, plus the flex fuel kit option with the ProEFI. Saad racing is making a complete fuel kit for the flex fuel setup, you can contact [email protected] for pricing information.
I have some plans for my car with the GT40, so I will have the stock pump, plus two 044's. I will also be installing a direct port nitrous kit as well! :)
Discussion Starter · #10 ·
Discussion Starter · #12 ·
Love it... I'll pull the trigger when I see a 2.5-3 build with methanol in the mix and retaining my HPF warranty.
I def want to be able to run the e85, Racegas plus meth numbers on cheaper then regular 93 fuel. So a 044 In tank? along with the Walbro inline? plus the injectors. Dont sound like to much. Im guessing once HPF releases the PRO for the HPF turbo kit they will include these things to make it full e85 complient
Discussion Starter · #17 ·
Stock in tank pump, with an external 044, two seperate fuel lines. The hat needs modified to make this work. Running two pumps in line with each other limits the volume. You get great pressure, but not near enough volume.
Unless I'm mistaken the Stage 3 has the upgrade fuel rail, two fuel lines and a few pumps to boot. Not the bosch 044 but I believe 3 walboros.
Could you essentially up the injectors on the Stage 3 and be pretty much good to go w/ProEFI + E85?
Discussion Starter · #19 ·
Possibly, I am not familiar with how they did that fuel kit. The stock rail is PLENTY big for whatever you want to do...it just needs modified to accept lines at both ends of the rail. We closed off the stock feed, and put -6 a/n fittings on each end.
1 - 20 of 71 Posts
