1 - 17 of 17 Posts
I have a non-sport 330i and i just got the m68 wheels from my buddies 330ci...so i went ahead and put them on, used my existing bolts that came with the original 17x7 wheels...and after i put them on and started to drive...the car is out of control...
1. I hear a rubbing/grinding noise
2. Wheel is out of control gets thrown left and right sporadically
3. Wheels wobbly, althoug a friend of mine looked at me driving and said that car/wheels werent wobbling
I've read somewhere that...the worst part about the staggered setup is tire rotation. it can't be done unless you want to change the rotational direction of the tires by swapping sides, and the tires aren't unidirectional ...did i somehow put the tires on the wrong sides or something...
P.S. the tires are very worn down...could that be a problem?
What is the problem, can someone please help me? I doubt that its rubbng....And im pretty sure that i snuggly put the wheels on so they fit into the groves..what can it be...Do i need a wheel alignment? I'm scared to drive it....HELP....
Discussion Starter · #3 ·
they were straight...they only have slight curb marks too...i looked at them i dont see any bents...is there a way to definetely to find out if they are bent? How?
teamdfl said:
Your buddy sold you a bent set of wheels.
Ed
If you have the correct stagger setup, then it's probably wheels that are bent or out of balance. Check to see if there are any flat spots. Jack up the car and spin the wheels.
Also make sure you use a torque wrench and do not overtighten the bolts.
Discussion Starter · #5 ·
Its the 17x7.5 in the front and 17x8.5 in the back...im positive that i put them in that way....
Are you guys sure they are bent? cause they look straight? Where can check? Maybe i need a wheel alignment?
Slow in, slower out
Take them to a tire place and spin them slowly on the balancer. If you can see any movement of the wheel edges, you will experience shimmy and vibration. For what its worth, I believe anything larger than .030" out of round or true is visible on a balancer
Ed
Discussion Starter · #7 ·
Will balancing them fix the problem?
How much can that run me?
also could it be the fact that the tires are out of round, since the thread is worn down, and looks uneven...more in the middle then on the sides?
Also is it bad to drive on them for the suspension, should i take them off immediately?
If it's out of round with a flat spot, balancing will never help. Had that happen to me with my previous car with aftermarket wheels. It is more pronounced in the front tires. Take it to a tire shop and ask them to drive it and see what's the deal.
Discussion Starter · #10 ·
going to try rebalancing....really *** it works...:ben:
does the steering wheel shake like crazy?Cuz on my 1990 accord the tires were extremely worn down and the wheel shook like crazy, but once i got some new wheels it drives like new.....I dont even feel like looking at it after i got the bimmer though
dude if re balancin doesnt help..there prolly ur tires..get new ones and properly get them balanced and aligned...and while ur at it be sure u check to see if they are bent or not...
Discussion Starter · #13 ·
Anyone think this could be a suspension or a bigger problem? i really dont cause this problem occured immediately after i put the new rims on and put the car in drive....?
damn some of u guys are gonna give the guy a heart attack...no one can really say what is the problem. something someone would have to look at to diagnose.
Here is what *could* be the problem
uneven tire wear
tires installed in wrong direction or wrong side of car
your front sway bar endlinks are not tight
your front bushings are shot
the rims are bent
the tire/s has a bubble
warped rotors(only applys to when u are pressing the brake)
all the above could translate to a wheel shimmy
Discussion Starter · #16 ·
can most of these problems be fixed with rebalancing....major problem that appears right now is the fact that the car is all over the place...wheels go everywhere, if i hit a abump, the steering wheel goes to the left or right without me even moving it....its like i dont have control of the car....
1 - 17 of 17 Posts
