1 - 4 of 4 Posts
This one has me stumped. I've looked everywhere but can't seem to figure it out. Here's the problem.
Last Sunday I drove home from Church and stopped at my house for about 10 minutes before heading home to work. When I got back in the car, it would not start. It would not even attempt to turn over. Although it seemed like a dead battery, all of my electronics (including my headlights) worked. I took another car to work, and when I got back I tried it again and it started fine. hmm? About 5 mins later I ran a battery test on it (by holding the trip reset and putting the key in the start position, clicking the reset button until test 9 shows up, then select 9, etc) The reading was about 120. I'm assuming this is 12.0 Volts? When I tried to start it immediately after that, it did the same thing as before work, unresponsive.
I jumped it from my dad's Ford Expedition and let it charge for about a minute, ran a battery test (with a reading of about 124), and it started fine. It continued to start fine for the rest of that day and the following day. It has been running fine for about a week since then. Today, I drove it to work, but after work it started being stubborn again. It acted like it was a completely drain battery although all the electronics worked fine. This time, jumping it was unsuccessful. We took it to Wal-Mart to get a battery test and they said the battery was fine.
Addition details- I have had some work done the last couple of months including-
New water pump​
new belt tensioner and belt tensioner pulley​
new idler pulley
The battery is about a year old and has not been drained in its lifespan.
The car is 2004 325i with 78xxx miles.
No "check engine" lights have popped up..
Help please.
Premium Member
Battery should read 12.5 volts after one hour of no load. Less than that indictes a weak battery and e46 has very finicky electronics.
Sent from my Droid using Bimmer App
Discussion Starter #4
Thanks for the help. I just got it started by just taking the connections off and back on the battery. It seems to me like it is completely random.
1 - 4 of 4 Posts
