Hey folks, I have a set of heated, E63 M6 seats ready to install in my '99 328i. I've spent hours reading up on the topic and I've determined that that this retrofit is entirely possible with the right parts and coding to disable the passenger occupancy sensor.
Seats fit great, trouble is, my early model E46 is equipped with the 18mm, single switch style console for the seat heat buttons. These individual switches only had 2 heat settings, high & low, and there appears to be differences between the individual switch wiring and design and the console style that came in most other cars.
I'm genuinely curious if anyone else has successfully retrofitted heated seats with the individual switch console. The official BMW instructions (linked below) point to a “required module holder” that must be ordered separately but it’s not clear as to what this part is. I assume it’s the new type console. This typically wouldn’t be an issue but I just spent ~$150 on the HVAC relocation single switch console as part of the OE navigation retrofit plus they never produced a switch panel with the old ASC button.
My question is, does anyone have guidance on retrofitting heated seats to use the old switch style console I currently have equipped? (see photo below)
Thank you!
Thank you!
