Is this post Helpful?
1 - 18 of 18 Posts
I spent my fourth installing new control arms and powerflex CAB on my 02 330ci and it wasnt easy. I started using the instructions at this post (http://forum.e46fanatics.com/showthread.php?t=140066) but figured out an easier way to do it.
These are the steps I took.
First we are going to go under the assumption that you have removed your control arm bushing from your car. you will also need one and a half inch steel pipe cap that you can get from home depot and a ball joint press which you can rent from autozone.
Auto part Automotive engine part
The first thing you want to do is press the in sleeve out half way.
Auto part
It should look like this when your done
Metal
Then using the pipe cap as an adapter, you want to push the rubber out.
Pipe Clamp Tool Metal
If it looks like this, your on the right track.
Gas
Then using a vise or a hammer you want to remove the rest of the rubber.
Auto part
Next using a hacksaw or a receprocating saw, you want to cut notches in the sleeve a the 3, 6, 9 and 12 oclock hands.
Auto part Tire Automotive tire
Then you want to bang in the sides like so.
Auto part
Then using the press, you want to push it in as far as it will go.
Auto part Wheel
Then using the pipe cap, you want to push the sleeve the rest of the way out.
Tool accessory Tool
The end result should be this.
Metal Games Auto part Household hardware Brass
Then press the bearing into the CAB.
Auto part
Make sure you press them in correctly. The back of the CAB is the side with the countersunk bolt holes. The side of the bushing with the small hole should be facing out that way. The side of the bushing with the large hole should be facing toward the front of the car.
Any questions, Please ask.
Discussion Starter · #5 ·
I bought the pipe cap from home depot for $2.50 and rented the ball joint press from autozone. Its free to rent, they just want a deposit which is fully refunded when you return the tool.
As far as removing the bushing and metal sleeve, I use brute force. It would have been easier with an impact wrench though. U need to secure the ball joint press to a vise or something similar when you are pressing out the the rubber and the sleeve.
Looks great. After doing the rear trailing arm bushings, I decided to buy the PowerFlex prefit bushings with carriers.
To remove my old bushings I actually used a gear puller (3 arm puller) and plugged and air ratchet into it. Once I hit the button, the bushing exploded out.
• DFW •
nice write up!
Look in the picture I posted above, I've pressed out the bushing out halfway using the ball joint tool. Why can't you press it out further? Because the bushing is now flush with the housing. There's nothing left to push on. If you have something that has a diameter that is slightly smaller than the lollipop housing inside diameter, but large enough to still push on the bushing, then you can use that. But that's precisely the problem, nobody has that magical piece.
I used an air hammer to get the remaining end of the bushing out which cannot pressed any further. Just put the lollipop in a vice, drill a small hole into the metal sleeve (for the air hammer grip onto something) of the old bushing and use the hammer to guide the sleeve out. I guess you could also use a chisel and a manual hammer instead.
Sent from my HTC One S using Bimmer App
I just ruined a lollipop. Wish I would've searched and found this thread sooner. This would be a great sticky.
If you do pay NAPA or someone to press these out for you (like for $66 mentioned above), you are probably better off just ordering these bushings already installed in the lollipops. Total cost difference between just the powerflex bushings, and a set of powerflex bushings already pressed into the lollipops is like $70, and no hassles or trips to a local shop.
However, if I had found this thread earlier, I would still probably try removing these bushings myself using some of the tricks here.
1 - 18 of 18 Posts
