1 - 15 of 15 Posts
2000 328i
Hello, my mirror switch hasnt worked since I got my e46 but the passenger side would point down while in reverse.
Now it is returning to a higher spot after reverse.
I dont really care for the pointing down feature, could I just pull the fuse, set by hand and have no power mirrors at all?
There are two fuses listed not sure if I should pull either or both.
Thanks!
Font Twig Rectangle Circle Pattern
Super Moderator
'03 325iT Mystic Blau
Thanks!
What happens if you put the mirror selector switch to the right?
Super Moderator
I had this same issue on my (now sold) 2004. The mirror tilted down as expected but neither mirror was adjustable. A bit of research on this forum and others suggested I replace the drivers side mirror to fix the problem. I sold the car before dong that.
I think that yours probably had the ribbon cable mirrors that did have the mirror control module in the driver's side motor, but OP's is a 2000, so it might be fixable by replacing the separate module.
2000 328i
Discussion Starter · #9 ·
Tested it out and I still get the reverse tilt with switch in either position.
Thanks again, Ill look into the module possibly
I seem to recall that mine tilted in either position and continued to do so even after I changed the switch.
Could very well have. In diagnosing the switch is the first step. Then it gets complicated for the master/slave (drivers/passenger) part and all that happens in-between.
I had the issue, 2000 model, a replacement window motor fixed it.
If i remember correctly the plastic gears for adjustment no longer
set in the proper location.
Sent from my iPad using E46Fanatics mobile app
1 - 15 of 15 Posts
