Hi everyone,
Going to be getting my subframe reinforced in the spring and was wondering if anyone here is running poly diff bushings. If you are, what bushings are you running and hows the NVH?
Thanks in advance!
I made an account just so I could I share my experience with you on this topic. Many other users have past experience with poly or solid diff bushings COMBINED with other poly or solid components such as also having solid subframe or motor/tranny mounts..
Recently after I bought my e46 m3 I notice a vibration at 2k rpm (and only at 2k rpm) along with a slight clunk/thud under hard acceleration. Very common in these models and some people will even tell you this is the "M Clunk". Anyway, my first thought was to change the Guibo or Flex disc along with center support bracket etc. I did this and it helped but did not completely solve the vibration and clunk..
I went back to my local shop and asked them take photos of diff bushing for me, sure enough they were pretty worn! Still driveable but worn enough to cause the slight vibration and clunk but only under hard acceleration. NOW, onto the purpose of this background information: I ordered the Revshift 80a poly bushings which they describe as an OEM plus+ feel as they are slightly stiffer than OEM, but not as stiff as many of the other brands that use 95A or 75D.
the Revshift 80a bushing COMPLETELY got rid of the vibration and the slight clunk. Both are completely GONE. I have no diff whine whatsoever no vibrations no squeaking at all (I have now had the bushings in for a week). Everything in my drive line is completely stock besides the diff bushings. Maybe this is why I don't have any NVH? I dont know if you have any other poly or solid components in your driveline or suspension but just know that if you are completely stock down there and you add quality 80a diff bushings, you should see little to ZERO NVH considering your car is in good condition. Also this information is not outdated and no other weird variables playing into it - like is said my car was 100% stock and I added the 80a diff bushings and it was perfect. Couldn't be more happy with them. I could make in cabin video for you if you needed heck i would even let you drive my car for yourself if you are in the PNW.
Anyway, just wanted to make sure you had accurate information from someone that specifically has poly 80a diff bushing with no other driveline modifications.
