1 - 9 of 9 Posts
Hey pros,
Need help identify this noise. It only happens when i m turning with speed. It used to only happen when making a left but now both left/right are making noises.
I found a video that has the exact same noises. could it be a bad diff?
This noise
Much help is appreciated!
2001 330ci with 220kkm. Recently replaced rear shocks/springs/shock mounts.
Sounds like a wheel bearing. Has it slowly been getting worst? You could only hear it when turning sharply at high speed, and now you're hearing it when turning the wheel only a bit, and at lower speeds? Maybe starting to hear it faintly when going straight?
Those are all classic wheel bearing symptoms.
Discussion Starter #5
its actually getting louder, before you only hear it accelerated turns, now even normal turns you can hear it. i know how wheel bearing sounds like tho but it just doesn't seem like like its wheel bearing to me. wheel bearing is more like a hum noise no?
this is more clunking/knocking.
What speed were you at in the video you posted?
Discussion Starter #9
What you're describing sounds exactly like a front wheel bearing. Is the sound coming from the front or the rear?
it's coming form the rear. its louder when i turn right, i had my diff fluid flushed recently, that didn't help with the noise at all.
1 - 9 of 9 Posts
