Today I changed my Crankshaft Sensor with a brand new VDO sensor, I don't have a voltmeter so I couldn't check if it was faulty. I changed the sensor due to the P0335 code and of course the no start ( as shown here ). But I also had the P0700 code show up as well and that scared me.
Again today I replaced the old sensor with the new one and made sure everything was in tact and sure enough the car did not start... it would crank but not start unless i held it there for a while (RPMS did not move at all while trying to start it). I then sat there clearing codes and trying again and the one code that stayed there was P0700.
I really don't know what to do right now other than to make this discussion trying to get help. I know there's other discussions but i haven't seen any where there's both P0700 and P0335... and where they replace the sensor and it still acts the same way and the P0700 code is still there and the P0335 isn't.
Symptoms i'm having:
• Car will not start unless it's held for 12 seconds or so and when started the rpms jolt up and down and soon after rough idle
• Gear light w/exclamation near the P (varies between P R N D S etc.) icon.
• Again Rough Idle
• Significant power loss and no low end torque (partially due to broken disa flap which I'm repairing today)
• Stalling (brake, light eml, dsc)
• Again Rough Idle
