Piston Soak DIY?
1 reading
26K views 12 replies 8 participants last post by  lingon300k
#1 ·
Looking for an e46 Piston Soak DIY. My car just broke the 170k mark and I'm sure it wouldn't hurt to get the rings a bit cleaner. Oil consumption is a bit higher than it used to be.
Found a video but wondering if this procedure hold true for the e46.
Thanks!
https://www.youtube.com/watch?v=-4olHcoRQII
#3 ·
You can never get all the carbon out of the rings. Have you ever hand scraped ring grooves? The carbon is super hard and there is a tool specifically made for cleaning. You can try soaking them with MMO.
#6 · (Edited)
I'll second the AC Delco stuff, I used it on my old engine and noticed my compression go up in a couple cylinders. Pretty much do what the video says, I used a funnel to make sure it all got in the cylinder, let it sit for a day (wasn't driving it at the time - 12 hours is pretty much okay though), then used my compressor & a rag to blowout any remaining fluid before starting it. It smokes like crazy for a bit & smells pretty bad, but I just let it idle half an hour then took it for a good rip up the street.
Sadly that motor was too far gone to save, as I found out when I tore it down, but there was a noticeable where the AC Delco cleaner did eat away at a good portion of carbon build up on the pistons, but more so in the rings.
I've also used the seafoam stuff where I sucked it in via the vaccum line, and put some in the oil & fuel, which helped as well. I usually do it about 300km before I change my oil so I can take it for a good rip a couple days to let the seafoam do its thing.
#12 ·
I've used Subaru Upper Engine Cleaner as a piston soak, and sucked in via vacuum line also.
Didn't work great as a piston soak as its an aerosol and the vapour didn't sit like a pure liquid.
Using it sprayed into a vac line works great, certainly notice a difference.
Whatever you use, don't forget to change your oil shortly afterwards once you've been out for a run.
#13 ·
ACDelco X66P--P for pour--the product recommended for this soak, is identical to BMW's upper engine/fuel injector cleaner.
You can see that the bottles are even identical:
http://www.eeuroparts.com/Parts/467...uel-Injection-Cleaner-Concentrate-82140428376/?gclid=CPrt38_l184CFY81aQodt-oO5A
https://www.amazon.com/ACDelco-X66P-Injector-Engine-Cleaner/dp/B0013FMW84
The Subaru aerosol, which is also highly recommended by many, is most likely the same product. This would make it identical to the ACDelco X66A--A for aerosol.
The ACDelco variants are often cheaper, which is why they're recommend.
You can't go wrong with any of them.
