In the last week my car has developed a horrible creaking sound coming from the drivers side front suspension. It's mostly noticeable at at slow speeds going over uneven pavement and when turning the wheel to the left and back to center from the left. No sound when turning right or back to center from the right. Also if i push down on the front left of the car there is some creaking.
From searching I'm guessing it's either the front strut mount or control arms/bushings. The car has 115k and the control arm bushings were replaced around 60k. Installed coil-overs at 95k.
My plan is to order the level one suspension rebuild kit and Meyle front strut mounts from ECS Tuning.
If anyone has any definitive solution to this problem that would be great. Or other possible parts causing the problem. Most things I found here were mainly guesses or people replaced multiple parts and it went away. Also any alternatives to the parts i listed that would be better would be great to know.
If people show interest I'll replace each part separately and take a test drive to find out which part caused it and post it here.
